disable mpls static lsp
disable mpls static lsp {lsp_name | all }
Description
Administratively disables one or all static LSPs.
Syntax Description
lsp_name Identifies an LSP to be disabled.
all Specifies that all static LSPs on this LSR are to be disabled.
Default
N/A.
Usage Guidelines
On executing this command, the software de-activates the specified LSPs by setting the administrative state of each LSP to down.
The following command disables a static LSP:
disable mpls static lsp lsp598
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
